Re: Tiling on tiles
If you are sure the existing floor is ok, make sure the floor is really clean and free from all grease and dirt and all tiles are sound and not cracked..
You can use
BAL Rapidset
A cement-based, polymer modified, non-slip, rapid setting, water-resistant and frost-resistant adhesive suitable for fixing ceramic wall and floor tiles including fully vitrified and porcelain, ceramic mosaics, quarry tiles, dark natural stone, terrazzo and brick slips. Suitable for a variety of backgrounds/bases including concrete/brick/block walling, cement:sand rendering, gypsum plaster, plasterboard, fibre cement sheets, cement:sand screeds, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt. BS EN 12004 C2FT Adhesive.
NOTE: The physical properties of BAL RAPIDSET with Porcel Bond Plus can be enhanced by the addition of BAL ADMIX AD1.
MAKE SURE THE TYPE OF TILE(BACKGROUND) YOU ARE FIXING TO IS LISTED IN THE INSTRUCTIONS ABOVE.
and grout with
BAL Microflex Wide Joint Grout
A Grey cementitious tile grout especially formulated with built-in Microban® antibacterial protection, to inhibit the growth of bacteria, such as Listeria, Salmonella, E-coli and black mould. The grout has built-in admixture to increase flexibility, and to enhance the bond to the edges of tiles. Conforms to BS EN 13888, Type C, Class G2.
