Discuss Tiling half a wall - large format tiles in the UK Tiling Forum area at TilersForums.com.
johnfrench10
Hi
I'm going to be tiling a wall in a bathroom with large ceramic tiles (600 x 300 mm). The tiles are going on to plasterboard (unplastered) and so I am OK with the weight limit ....just. The tiles come to about 28 kg/m2 so with adhesive I should be just under the 32kg limit.
The top half of the walls are going to be plastered and I am planning on putting batons on the wall at the tile height for the plasterer to skim up to and then tile after. This will give me a nice straight plaster edge to tile up up.
The thing is I will want the tiles to stop exactly at the plaster which means tiling from the top down. Will this work for tiles this big...they weight about 4kg each? I currently have some Mapei kerraflex left over from another job but can change to a quick set if this will help?
Thanks for your help guys
Reply to Tiling half a wall - large format tiles in the UK Tiling Forum area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
