Discuss tiling halfway up a wall in the British & UK Tiling Forum area at TilersForums.com.
tileform
I'm currently tiling halfway up a wall but after stripping the walls etc and prepping i've discovered the walls are up to about 8mm out in places.
Now this normally wouldn't cause me a problem tiling to the ceiling with back buttering etc but has anyone got any ideas for when i come to fix the trim?
I know with the walls being this far out, the trim is gonna look horrendous - its a PVC trim with a mosaic kind of pattern
Customer does not want to pay for plastering the walls :furious3:
Much appreciated guys
GazTech
I have had this problem before, tile as per the normal keeping them straight. The last row leave the adhesive shy from the top by the depth of the trim back ( the bit behind the tiles). Then fill with adhesive and slip the trim in flush with the tile face. Finally use Ardex feather finish to feather from the back edge to nothing....this stuff is sandable and paintable in 2 hrs....Gaz
ARDEX FEATHER FINISH
Size (pack): 11kg bags, 5kg tubs.
Coverage: Up to 50m²/bag as a skim coat, 10m² at 1mm thick.
Specially formulated for thinner repairs, this rapid drying smoothing and patching compound is used for filling and feather finishing on plywood, concrete, cement/sand screeds and existing ceramic tiles, receives floorcoverings as a scratch coat after only 15 minutes on absorbent sub-floors.
Reply to tiling halfway up a wall in the British & UK Tiling Forum area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
Hi all, This forum has been a wealth of knowledge for me while i tackled our new build. A...
Deleted member 59001
5K
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
