Discuss Tiling in a Mobile / Park home in the UK Tiling Forum area at TilersForums.com.
thearge
Hi everyone
I am a competent Diy'er and have undertaken a re-furb on a Park / Mobile home, everything is going well and i am soon to undertake tiling the bathroom, i have had various suggestions regarding the best way to successfully do this, the walls are pretty flexible and apart from inside the shower enclosure which has been overboarded they have just been stripped of the original wallpaper. Overboarding of the walls is not really an option due to construction of the home, will i get a successfull result by just tiling and using a flexible type grout ?.....any suggestions will be greatly appreciated.....Steve ( Luton )
peckers
theres no easy way to tile a caravan most of the walls are 4mm hardboard. you will have to remove the boards and add extra fixings to the studwork frame of the caravan. If i remember rightly its only 2x2 as it is. you will have to add extra support to the frame work and then i would use a 10mm hardi backer board as this is a cement board and it is moisture resistant. this will interfere with your windows as these normally finish flush with the existing wall finish. you may have to form your own reveal at this point you can either tile it or you could use plastic window trims to cover this, the same would apply to the door frame too.
the problem you have is that the way the caravan walls are constructed at the moment is that if you lean on them then they move and bend! this would make the tiles pop of the substrate.
theres quite a bit of work involved before you get to tile.(but it can be done)
BoldreChris
Hi Steve and welcome to the forum. I've done a couple of kitchens in park homes and the walss are very flexible indeed. Traditional tiling techniques just wont work, even the super flexi adhesives and grouts can't take that much movement. So (and I'm going to get a lot of flak for this, I expect!) I've resorted to using flexible building adhesive to attach the tiles and silicone to grout them. The best adhesive at the moment is FlexTec FT101 and it bonds very well to the mobile home wallboards.
The tiles have to be thoroughly degreased before grouting - alcohol wipes or similar do the job. It's a pretty tedious job to grout with silicone but you can clean the gloop off the surfaces and get a fine finish using white spirit but only within maybe five minutes of first squeezing it in.
Hope that helps. Good luck with it...
JRCCR
I subcontracted for a company last year who manufacture park homes throughout the UK, they are based only a few miles away from me. They used 12mm ply on the floors and the walls were 18mm and they were tiled before transportation to the location they were going.. Never had any problems until the homes settled in, thats when some of them started cracking. Nice homes and nice park sites but very cheaply made. My main part in this was travelling UK to rectify the problems.
Reply to Tiling in a Mobile / Park home in the UK Tiling Forum area at TilersForums.com
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
I am planning to get 1000x1000 tiles in my kitchen from the following website. In the quote they...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
TF Group Please Join
Tilers Forums on FB
