Martin Harrison
Hi. We are tiling a ground floor kitchen that is half suspended floor (100x50 joists on 300 spacing, with supports every 1200mm) and half concrete slab. The concrete slab has just been poured and once insulation has been added, it will have UFH pipes buried in the screed top layer. The tiles to be laid are 600mm 11mm thick ceramic.
I was originally looking at this site to try and understand what the best subfloor would be for the UFH. The UFH system the builder is looking to use is Nu-heat. The pipes are laid in 15mm of gypsum board, so it isn't structurally strong. As my joists are small, it sounds like I need some good reinforcement before laying the UFH to prevent bounce. I want to do that without impacting the finished floor level too much - which would otherwise have an impact on the door thresholds to the rest of the house. What is considered correct - plywood, what thickess, ditra matting, priming etc? The builder is suggesting doubling up the joists and bolting them together. He's been advised that the original floor boards could then be put back down but I think we should put plywood, screwed and glued. Can anyone advise?
In reading many of the forum comments it also looks like I may have an issue where the suspended floor transitions to concrete - as i won't be able to eliminate all movement in the wood? Is that correct? If so, what's my best option here?
