U
Unregistered
Hi,
I've just had tiling done in my kitchen and I would appreciate opinions on if it's been finished correctly as they are the first tiles I've had done - the tiles are 'subway style' 100mm * 200mm to be installed with trim.
Questions:
- the depth from the sink to the window was two and a half tiles - the half time lined up to the trim on the edge of the window - however, all along the trim I can see the cut lines of the tiles - all jagged - is that normal or should grout / other filler have been put in to give it a smoother look?
- is it unreasonable to have expected trim corners to fit together evenly?
- I had 5mm tiles and 7.5mm trim - as per b&q guy - but some of the trim has big gaps over the tops of the tiles - is that my fault for buying the wrong ones? It doesn't happen in every place
- is it unreasonable to expect the silicon sealant to be smoothly applied rather than lumpy in parts?
- should the grout have been allowed to dry fully before sealant applied? It is grey grout and the sealant appears dirty in parts - like it mixed in together?
The installer is coming back to look but it would be great to know from experts if I am being unreasonable!
Thank you,
Michelle
Questions:
Thank you,
Michelle
