Discuss tiling large areas setting out help in the UK Tiling Forum area at TilersForums.com.
brundlefly
i wouldnt break it at the door ways unless you have explained to the customer first why you had to,it may fall ok,
best thing i do is spend a 1/2 day setting out, center the main entrance and run a few lines through to the other rooms,dry lay some tiles if you feel you can visualise it better ( i do), see how the cuts fall then explain the solutions, i do put a mastic joint on every door way usualy between 5 & 10mm the customer will want the smaller joint they always do ;), if theres underfloor heating ?...heated screeds i always use, (PCI Pecilastic mat and nanolite)
bobbin
Schlüter have various movement and joint profiles in various finishes, check out there site. Not sure what is recommended but anywhere from every 5 metres to 10 metres you need to provide a movement joint. You don't want it cracking, and by the size of it there is every possibility it could, I guess there will also be heavy traffic as it is an office.
Reply to tiling large areas setting out help in the UK Tiling Forum area at TilersForums.com
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Dear Tilers, my husband has done a lot of tiling, but would really like your advice please. He...
Hi everyone. I'm really hoping you all can help as I am at my wits end. We have hired...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
