Discuss Tiling marble onto paramount board in the Canada Tile Advice area at TilersForums.com.
I
ian158
I quoted a job a few weeks ago and noticed its paramount board wall with another sheet nailed on top..I told the lady to only get ceramic because of the weight issue...and that fixing Hardi everywhere using cavity fixings will up the price...she's on a budget .she now says she has bought marble tiles...! No way can I fix these floor to ceiling on paramount board right..
DHTiling
How do you guys fit hardi to drywall..or paramount for that matter...I thought of the drywall fixings...the ones where you use the racket gun to spread the fixing...but the head of the screw is too proud..unless I just use an 8mm float but putting more weight on...gulp !
Some times you can remove the skin and frame and re-board. Then you do not disturb the skin the other side.
Otherwise 4mm marmox and expanding hollows
Protilers
thankfully its not used anymore..it was 2 sheets of plasterboard with a honeycomb centre..like a sandwich board..no stud..it was a cheaper way of dry lining..now its metal stud and dry lining now..
oooooohhhhh.....i never knew that it was called "Paramount board!".......everyday is a school day EH!
thanks
Lee
Reply to Tiling marble onto paramount board in the Canada Tile Advice area at TilersForums.com
Budget renovation as I just bought the flat. Cavity brick walls, 1 external. Removed old tiles...
Paramount wall fix for tiling ideas? the plan is (or was) to tile floor to ceiling with 200mm x...
Marmox Boards 12.5mm.... are they any good for Tiling onto floor boards? I normally use hardie...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
