Discuss Tiling my bathroom, any advice? in the Bathroom Tiling Advice area at TilersForums.com.
Will Blackburn
Hi there.
I am tiling my bathroom which has been plasterboarded with Gyproc moisture board. Do they need any sore of primer? Can they be waterproofed any more before I tile?
The budget is low, but what adhesive do you recommend for the walls? What grout? Its a small bathroom being tiled with 600 x 300 white tiles.
The floor will be done with 500 x 500 black/grey ceramic floor tiles.
My floor is currently floor boards but I plan on laying some plywood first then tingling right onto that. Do I need to prime with PVA or anything like that?
Again any recommendations for adhesive and grout?
Q
Qwerty
My advice to you would have been to use standard pb, then tank the areas that need waterproofing.
As for adhesive & grout.....you will get various different responses as people use all sorts of makes. The main brands are Mapei, Tilemaster, Weber, Ardex, BAL.
Never use PVA for tiling, use a dedicated primer the same brand as the adhesive and you would be hard pushed to go wrong
Will Blackburn
Thanks. Should I tank this moisture stuff?
Found someone not far with Weber Set Plus adhesive for £9.99+vat per 20kg bag.
Would anything I have described require priming?
Time's Ran Out
My advise would be to get a pro tiler to do the job.
it may cost a bit more but at the end of the day you won't have the nightmare of it going wrong.
Reading some of the questions in this forum of late I don't know if your advice is correct.
Only get a 'tiler' in if you've seen his work.
Stef
If your going to use set plus then get a bottle of Weber pr360, that's the primer I use most of the time.
Very good adhesive with a long working time..
Noticed on the other thread that MZ is close to you, why not contact him & get him to give you a quote for the job??
Indeed above,
but for all we know there might be a perfectly good Tiler living in the next street, or even a forum member, living close, struggling to fill his diary and paying the bills... whilst a Teacher/Doctor/Engineer etc decides to save a few bob and have a few weeks hobby while they're on strike or whatever..
Probably not even relevant to the question poster, but in general its my opinion!
Stef
Some folk are going to do it themselves, so instead of the "get a pro in" default answer. Wouldn't we be best just giving advise?
Some people would be surprised how much a job would cost if they got a tiler in.
By the time the op gets all the relevant tools then they may not be saving that much.
TJ Smiler
Weber is fantastic stuff and thats a good price too....... If i was doing it i would be using a flexible adhesive (Especially on the p/board whether it's been dabbed or studded) Weber.set spf is lovely........ if your DIY and your planning on using a light coloured grout then i would also use a white adhesive to help keep your end grout finish perfect.
Reply to Tiling my bathroom, any advice? in the Bathroom Tiling Advice area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Unsolved
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
