Guest viewing is limited
Discuss Tiling new conservatory in the Canada Tile Advice area at TilersForums.com.
We are building a 4x4m conservatory and the base is one from durabase.co.uk. It is made up of steel frame with beams running across then with 18mm MR chipboard screwed to the beams.
I will be screwing every 200mm to the beams to reduce any movement in the boards. Then laying cement boards over the top before tiling.
My question is, what type of adhesive do I need under the cement boards and also what type for fixing the tiles (300x300). Will I need flexible type ??
Thanks for your advice on this.
Mark
Use non rapid, unless you are grouting same day or need to walk over them.
Gives you time, no matter how experienced you are in diy, some rapid does exactly what it says on the tin
yep especialy if its warm in there goes vey quick but exellent stuff
Reply to Tiling new conservatory in the Canada Tile Advice area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
gamer1
Stafford
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
