Discuss Tiling newly skimmed plaster in the Australia Tiling Forum area at TilersForums.com.
It will say on the tubs which primer to use if any and im 99:9% sure they will tell you only to use there's , imo thats because they then make two sales instead of one and I have never had a problem where I have used a different manufacturers products, the problem there is that if you dont use theres your guarantee on the product will be void, check with your tile shop also
Reply to Tiling newly skimmed plaster in the Australia Tiling Forum area at TilersForums.com
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
