Discuss Tiling on existing ceramic floor tile adhesive in the British & UK Tiling Forum area at TilersForums.com.
U
Unregistered
Have just lifted ceramic floor tiles from the bathroom prior to replacement with new tiles.
The tiles have come off but most of the adhesive is still left attached to the floor. The adhesive seems very firmly attached and removing it is proving very difficult - it is impossible to do it (using hammer and chisel) without damging the underlying cement screed.
Is it possible / sensible to fix new tiles on top of the adhesive residue? If so the are there any special recommendations for how to do the job (e.g. type of adhesive, priming needed, levelling etc). (I know that this will raise the floor level slightly, but this is not a problem).
If not, then any tips on good easier ways of getting rid of the adhesive (don't know what kind it is, but there is quite a thick bed of it).
Many thanks
Ajax123
1,213
Lincolnshire
I not a tiling expert - just throwing this into the mix cos I don't know the answer. If the adhesive is so well stuck to the screed that it is not moving much with a hammer and chisel and height is not an issue would it not be fesaible to simply use SLC then Ditra......
Ajax123
1,213
Lincolnshire
Having said that if the adhesive does need to some up then - I hestitae to say it cos I know the flack I will probably get - but you could always hire a needle scabbler and scabble the surface of the screed........:yikes:
Reply to Tiling on existing ceramic floor tile adhesive in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
