Discuss Tiling on floor grade mastic asphalt in the America Tile Forum / Advice Board area at TilersForums.com.
I'm about to tile an area 2m X 10m in a kitchen area. The floor is covered with floor grade building mastic, hard, black, around 20mm thick.
I'm planning on using a decoupling mat after cleaning and using Sbr on the asphalt.
Part of the bitumen is uneven, to about 1cm over the 2m width. I'm not sure if, before applying the matting I should:
1. Attempt to reduce the uneven section. I'm not sure if it is safe either.
2. Can levelling compound be used over bitumen? I'm wary of using different substrates.
Any advice would be welcome.
Reply to Tiling on floor grade mastic asphalt in the America Tile Forum / Advice Board area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
USA Tile Forum Popular
America Tile Advice Trending
BD13 3DP
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
IT Specialist
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
