Discuss Tiling on lath and plaster walls in the Canada Tile Advice area at TilersForums.com.
robbieee
Hi everyone!
First post so be gentle....
I am doing up my bathroom for as cheap as possible so i am doing myself.
The problem is that i want to tile the full room from floor to ceiling with 600x300 tiles (travertine effect ceramic probably).....But 2 of the walls are lath and plaster (skimmed). I am just taking the cautious assumption that these walls won't be able to hold the weight of the tiles. I have read that you should take the plaster back and attach plasterboard (dot and dab). But if i do that, the wall will come out further than the door frame. Is there anyway to avoid ripping the full plaster down and having a wall solid enough to hold the weight?
The walls look in decent enough condition...
Any advice would be much appreciated on how to overcome this problem. Or am i being over cautious?
Ajax123
1,213
Lincolnshire
The lath and plaster walls will be stud work and so will not be suitable for dot and dab. The plasterboard should be screwed to the studs. This will mean it will not protrude further forward than the door frame. Don't skim the walls as this reduces the weight bearing capacity.
robbieee
Thanks for everyone's input, very helpful!
So if i strip out the wooden laths (and plaster first of course), then attach plasterboard to the studs- what sort of weight with this then be able to hold? (will it then support the 60x30 tiles i want?)
Also- would you advise to get the walls skimmed as the walls won't necessarily be square/level for putting the tiles on?
Rizzle from the Portizzle
well in the old days you would drill holes at the top every 150mm put a small hose throught the holes atached to a funnel then you would mix unibond with 70% water and pour in then you would go down half way drill holes again and repeat leave three days to dry with the lime plaster and hores hair and lathes it would harden like concarete give wack with hammer to test its strengh then tile
Ajax123
1,213
Lincolnshire
Please no jokes about hores and their hair ;)
White Room
what!!!!!
robbieee
Anyone help?
Also would i use the moisture resistant gyproc?
Reply to Tiling on lath and plaster walls in the Canada Tile Advice area at TilersForums.com
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hi, so I’m relatively new to tiling. I’ve got a job where the walls aren’t 100% flat but not the...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
