Discuss tiling on paint in the British & UK Tiling Forum area at TilersForums.com.
Allyc
hi guys, whats your info on tiling on painted walls. what i do is score the wall alot with knife then scrape of any flaky or loose paint, prime and then tile. there is times all the paint will come of with a soak and a scrape, but at times it wont, and the amount of efford trying to remove the paint, ends up pulling the plaster off. so if its bonded that much, i just tile on to it. ive done this for years and it works well i think,,,,,,, any info ??
Diamond Pool Finishers
well my advice would be to remove it completely ,or you have other options, like to overboard with plasterboard,tile-backer,cement board, you could hack-off the plaster and re-do with render if a solid wall.
don't tile on to the painted wall though as the tile adhesion is only as good as what is on the wall already !! and paint lets face it is not good,
Reply to tiling on paint in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
tiling on paint
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
