Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Tiling on Plaster - Close to Weight Limit in the Tiling Standards area at TilersForums.com.
crawf94
Hi, new member after a bit of advice from all you experts.
I am tiling my bathroom which has three plasterboard walls (unskimmed) and one block wall (plastered). The tiles I have weigh 16kg/m[SUP]2[/SUP], so with the weight of the adhesive and grout this puts me right on the 20kg/m[SUP]2[/SUP] limit. Would tiling the plaster wall be a big risk or is there already some safety margin built into the 20kg weight limit? I was thinking of hacking off the plaster and dotting and dabbing plasterboard onto this one wall. Am I correct in thinking that dot and dab plasterboard will have a weight limit of 32kg/m[SUP]2[/SUP] like the other bare plasterboard or is it a reduced limit because of the dot and dab fixing?
Are there any alternatives, bearing in mind that I don't want to bring the wall out any further than it is as the bath is already a tight fit and the soil pipe is right up against the wall currently?
Dan
Admin
Staff member
5,086
1,323
Staffordshire, UK
Plasterboard does have a stronger weight limit you're right. But as long as you're on the 20kg and not much over, you'll be sound - as said above.
Just try not to pack out much. If needs be, stick a big straight edge over the wall and if any bits of the wall stick out (corners etc) chip them back a bit - rather than packing out the middle of the wall to meet. Sort of thing. You'll use a bit less adhesive there then and wont go over the limit.
crawf94
How big are the holes.....
Sorry for the delay in responding.
Most are very small just bits of plaster that came away when the old tiles were taken off. 1cm deep maximum. However, there is an old shower valve and plumbing to remove also which will obviously leave quite deep holes.
Reply to Tiling on Plaster - Close to Weight Limit in the Tiling Standards area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Hi, so I’m relatively new to tiling. I’ve got a job where the walls aren’t 100% flat but not the...
Tiling Standards
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
