BRITISH
STANDARD 6.2.4.2
Sheets and boards
Sheets and boards include the materials listed in
6.1.2.6
, except
plasterboards; sheets or boards should be adequately braced to
provide a rigid surface, be free from any springiness and surface
undulations and undergo no subsequent distortion during and after
completion of the tiling. Wherever possible, the boards should be
screwed, not nailed, to the supporting framework.
In general, where the sheet or board has a smooth and a rough side,
the latter should be used for tiling. The surface to receive the tiles
should be clean and free from dust and other forms of
contamination.
The use of sheets and boards that are subject to movement from
changes in moisture content, e.g. wood-based materials such as
plywood, chipboard, wood particle boards, etc.,
should be avoided if
at all possible. If such boards have to be used, they should be
restricted to small areas and tiles should not bridge joints between
boards. All exposed edges and the backs, but not the faces, of such
boards should be sealed with a suitable sealer to prevent distortion
by atmospheric humidity changes. Care should be taken to ensure
such boards are not installed in a condition where their moisture
content is higher than the ambient equilibrium moisture content
once the tiled installation is in use; failure to observe this can lead to
subsequent warping and distortion of the boards with consequent
cracking and delamination of the tiling.
