Discuss Tiling on polypipe ufh overlay boards in the Canada Tile Advice area at TilersForums.com.
prbrown
DIY Tiler
Hi Newbie here (DIY - small jobs only!)
Need to get a pro in to do a floor (35m2 or so kitchen/utility room) which has had polypipe ufh overlay boards freshly laid down. Tiling with a 600 x 300 porcelain floor tile.
Question is what is the best option to tile on the boards - poly pipe have give various answers depending on what time of day i call from tile direct on top (with flexible adhesive), put down a membrane (ditra tilmaster etc) through to you should put down hardie backer boards first!
I'm trying to keep the floor build up to a minimum (as well as cost!) but dont want to cause problems down the line if leaks / new floors needed etc.
Any advices on best way forward appreciated. eg is there a thinner cheaper alternative to hardie backer boards that wont act as a heat barrier?
thx paul
Hi and welcome to the forum Paul.
There was a thread similar to this last week.
Have a read, if you have more questions that’s absolutely fine.
There are two methods explained, my preference is toward the end.
Hope this helps.
prbrown
DIY Tiler
many thanks - thats really useful
so hardie backer boards wouldnt be your preferred route - Humm
reason i thought these would be good is to give areas (around walls/pipe return/doorways with exposed pipes runs) a level surface to tile against. eg see photo
i dont really want to use a SLC/adhesive to enclose the pipes - polypipe dont recomend/guarantee that
if i use detra25 matting my guess is the pipes would be covered by adhesive so a bit of catch 22.
the boards build up more and will cost a bit more (but not significant when adhesive/time etc taken into account) but will be easier to lay (i think/assume) - 6mm is a bind though!
ps the doorway and return are going to have to have an insulation board (10/12mm) under those pipes which the builder "neglected" to remember to fit !!! so the pipes will be flush with the overlay boards.
Do you have a copy of polypipes installation guide lines?
when using slc over polypipe it will not cause pipes to lift,,as far as I’m aware that was an old theory they had.
once the slc has been laid use a 1mm antifracture mat instead. Ditra matting is overkill.
[automerge]1570734918[/automerge]
To keep guarantees in tact then following their guide lines is all you can do.
Bill
I have tiled directly to poly pipe boards.......no problems ....would I do the same method again?
No - I would use a suitable primer first but I wouldn't necessarily use an SLC as I don't see the point if the floor is level.
I used Norcross adhesive too so not one of the heavyweights in adhesive terms.
Sometimes your gut instinct will tell you if it will work or not.
Using the SLC Tom gives a a solid one piece floor with excellent and even transfer of heat.
and if you pressurise the system with cold water before hand to around 5 bar, you create enough room for the pipes to expand and contract during heating cycles.
and with an antifracture mat the whole system works really well.
yeah, instinct can go a long way.
Reply to Tiling on polypipe ufh overlay boards in the Canada Tile Advice area at TilersForums.com
Hi. Need some advice. I've laid down polypipe plus overlay boards in my house. My tiler says we...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
1950s ex council house, solid concrete floors, about to have the ground floor tiled - hall...
Morning all, I have been given the opportunity to quote for a 110m floor in a chevron pattern...
prbrown
DIY Tiler
united kingdom
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
none
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
