J Sid
so no test has been done on tiling these boards?
The boards are fine and have been tested, the pipe is also fine with being tiled on and has been tested. However, the pipe hasn't been tested with a primer. The chemicals that a primer contain could have a corrosive substance or something the pipe doesn't like.so no test has been done on tiling these boards?
That would be fineok, understand.
so boards need priming and aloud to dry before the pipe is fitted in groves, yes?
