Discuss Tiling onto new plaster in the British & UK Tiling Forum area at TilersForums.com.
a gypsum base coat will retain its moisture far longer than a plasterboard,it breathes moisture!, as a rule of thumb I'd tile skimmed plasterboard after 2 weeks, basecoat and skim probably about 5 weeks before tiling. Ideally tho' I wouldn't plaster onto skim because of the weight bearing (20kgm2) issues.:dizzy2:either plasterboard OR backing coat,.
6 weeks, why? I thought skim plasters dried out within a week. On domestic properties I cant see customers beeing to happy if you said it cant be done for 4/6 weeks. Thay will be wanting to get their kitchen or bathroom back to normal??
any comments
would you rather wait or do it twice?either plasterboard OR backing coat,.
any comments
yes, that is what I meant!!
When u need too as long as its dry lol :smilewinkgrin:
ok so basically moisture in the backing coat will make the adhesive unbond. fair enough. but
plasters only 3mm ish thick on boards and old walls e.g unibond and skim - there no moisture left in skim after 3 or 4 days. the old walls and boards suck the water out of the skim. ???
:mad2:
Reply to Tiling onto new plaster in the British & UK Tiling Forum area at TilersForums.com
