Discuss Tiling onto painted plasterboard drywall in the British & UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,099
1,323
Staffordshire, UK
Make sure you score the plasterboard along with sanding it. Scoring it diagonally every 100mm or so to create diamond patterns in the plasterboard will help give the adhesive a good key. Then sand the walls down with a course sandpaper (doesn't have to be all gone, just most of it, and scored and sanded to shreds) then prime with a good primer. Don't use PVA!
brian c
Dose scoring into the the surface not weaken the plaster bond?
I have always just keyed the surface up with some 40 or 30 grade aluminum oxide break down the paint and key the surface up, Dust off then prime and then tile.
you are only supposed to score the paint not the plasterboard.:thumbsup:
Reply to Tiling onto painted plasterboard drywall in the British & UK Tiling Forum area at TilersForums.com
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
