Discuss Tiling onto SLC in the British & UK Tiling Forum area at TilersForums.com.
TheRealRobG
I've just laid self-levelling compound (Wickes Master Latex) ranging in thickness from 3mm to about 8mm. This was laid to encapsulate a heated floor element and to level the floor surface.
The SLC is on top of a 12.5mm layer of Aquapanel, which is laid with a 3mm bed of waterproof tile adhesive and screws onto a 21mm water resistant chipboard floor.
I'm going to lay 450x300mm tiles onto the SLC using Bal Rapidset Flexible, and have a few questions:
1. How long should I leave the SLC before I can tile? It's been down 24 hours now.
2. I have a 20mm solid bed trowel - will this be suitable for the adhesive and tiles I have?
3. Should I prime the SLC? The tile factsheet seems to suggest no need to prime sand based screed, but it doesn't specifically list SLC as a substrate. I have some Bal APD to hand.
Thanks!
TheRealRobG
Bottle doesn't list SLC unfortunately. Only:
USE UNDILUTED ON:
-plaster walls/plasterboard when using a BAL cementitious powder adhesive
-tongue & groove floorboards
-anhydrite screed floors
USE DILUTED 1:1 with clean water on:
-dusty/porous plaster walls when using a BAL ready-mixed adhesive
-cement: sand screed/concrete floors
Reply to Tiling onto SLC in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Tiling onto SLC
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
