Discuss Tiling outside areas in the British & UK Tiling Forum area at TilersForums.com.
N
Newby Jo
Hi.i would use weber 1 part flexible adhesive and weber wide joint grout.most important thing is to make sure the tiles are vitrified.just protects against frost.
Thank you for you advice. I know the tiles I have in mind are vitrified so now I just need to get the adhesive and grout you recommend. Is there any need to seal the whole area afterwards?
Reply to Tiling outside areas in the British & UK Tiling Forum area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
