Discuss tiling over chipboard over water underfloor heating. in the UK Tiling Forum area at TilersForums.com.
jonnyc
got a couple of bath floors , where water underfloor heat pipes set in metal trays between the joists.
contractor has overboarded with 22 moisture resistent chipboard . tonge/grovved and screwed.
no movement under foot.
I used to lay ditra over chipboard but schluter now say they will not guarantee ditra over timber substrate with water.
trimlime have told me their 6mm cement board xl like hardibacker screwed in to chipboard will be suffice.
is this ok or any other suggestions
jonnyc
May be wrong but would the cement board not block the heat too much?
no apparently it lets heat through the board unlike marmox/dukkabaord/wedi or similar.
they say that apart from letting heat through it is a good background to tile on to.
its just 6mm seems very thin but i guess that if chipboard load bearing adn rigid fix , the xl board is just giving a good substrate to fix to.
i have always fixed ditra in the past in this scenario , but now schluter dont recommend
Reply to tiling over chipboard over water underfloor heating. in the UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
