Discuss tiling over electric matting advice needed! in the British & UK Tiling Forum area at TilersForums.com.
steve mason
Been asked to tile over electric matting 3mm thick with 60x60 tiles. The matting is being put down over a concrete floor 18m2 in total,what adi/grout do i need,how should i apply it ie cover the floor or butter back of tile. Plus can i just use adi or should i put something else down first? the customer has told me that you can just lay the tiles straight on top but i wanted some advice from you guys instead!
DHTiling
Hello steve.....
You will need flexible adhesive and grout......
as for tiling straight over..then YES you can...but i and a few others on here like to level over the UFH with a latex leveller then tile....
1: this gives the mat some protection when tiling over it
2: and it gives a nice flat floor to tile to with large tiles like those or mosaics etc.....
Just a quick question as well steve....is the floor insulated.?.
as tiling straight onto a concrete floor with UFH can be expensive to run....
steve mason
Cheers guys for advice ill ask the customer whos a friend if the floor is insualted and the what product would you by to cover the matting before i tile over it? How is it applied and how long to dry before tiling over it? Sorry for so many questions but jobs in lincoln and im in wakefield so need to get kit sorted before i travel!
Reply to tiling over electric matting advice needed! in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Im changing a bath to a tray for a friend and the bath was chased into the wall on all 3 sides...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
got an 80m2 porcelain job upcoming ....seagrass carpet currently down on top of foam backed...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
