Discuss Tiling over the bath in the Australia Tiling Forum area at TilersForums.com.
ripkord
Hi all, my bathroom tiles are circa 1990, ie horrific so need to go.
Unless times have changed dramatically I'm assuming tile paint is still utter nonsense and doesn't give you a decent finish?
Anyway assuming that is the case I was going to pop down the tile shop get some plain white tiles, some waterproof BAL adhesive and retile the lot. The area I intend to tile is from the bathtop to the ceiling on the 3 sides of the bath (bath is snugly in one side of the bathroom).
The existing tiles are on plasterboard, any tips for getting these off cleanly?
I have done a bit of floor tiling before (which turned out great thanks to you guys) and have successfully tiled a bath panel so - should be OK doing this. Do I need to tank the walls? Also on the gap between the bath and tiles is it best to leave a gap and Silicon or grout then Silicon (I hate that bit, someone else might be employed to do it lol)
Anything else I should be concerned with?
Many thanks,
If your tiles have been half decently fixed, it will be impossible to get them off without damaging the face (paper!) of the existing board. If you are prepared to tile on plasterboard, take the board as well down, it makes it easier anyway to do this. When and if you are going to put plasterboard back up, at least use the green moisture resistant plasterboard, tape the corners and use a suitable adhesive. Most importantly in my opinion use a good quality "flexible" grout to limit any hairline cracks thus avoiding water ingress to the plasterboard. Hope this helps. Oh there will be many that would say don't use plasterboard at all...........you pays yer money....you take yer chances.
Rich Midge
608
Liverpool
I agree with timeless, just tile over. Make sure your existing wall tiles are spotlessly clean and dry, no soap residue etc. Allow at least 3 days after tiling before you grout and another day before you Silicon. Leave the tiles a couple of mm above the bath. Half fill the bath with cold water and Silicon. Leave the water in over night.
ripkord
Thanks for the replies guys. Tiling over isn't an option as the tiling isn't great. I'm in the process of trying to get them off without wrecking the plasterboard but looks like that's going to be impossible. Will most likely have to pay someone to install aqua panel then retile. Think this goes above and beyond my "expertise". :(
Edit yup looks like water has been getting in behind tiles unsurprisingly. Oh joy. Mushy plasterboard.
Reply to Tiling over the bath in the Australia Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
