Discuss Tiling over thermolite blocks in the Canada Tile Advice area at TilersForums.com.
shosho
:mad2: this sums up my frustration!
doing up my bathroom at the moment and i need to tile the walls around the bath. currently there are some tiles round the bath however these are very old and there is insufficient tiles covering the walls.
The main wall along the bath is made up of thermolite blocks, so i have been told.
the question is what is the best way to tile over such walls.
would be most grateful for any advice.
Bubblecraft
Just standard British Gypsum Drywall Addy will do
When you say what material to tile the tiles on the wall, do you mean the tile material like ceramic or porcelain or the adhesive to put them up? Things to consider when picking you tiles, make sure your tile inc adhesive & grout does not exceed 32kg pm2. That is your max weight limit for tiling onto PB. The tile you pick will also determine the adhesive to be used
Reply to Tiling over thermolite blocks in the Canada Tile Advice area at TilersForums.com
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
  • Sticky
Hi everyone. I have a 1940's semi and i have been redecorating my front room, no its my own...
Tilers Forums on FB
