Guest viewing is limited
Discuss Tiling over underfloor heating pipes in chipboard in the Australia Tiling Forum area at TilersForums.com.
H
hewrigg
I am in the process of converting a barn into a dwelling and have installed underfloor heating pipes into 40mm chipboard by routing out pipe channels to lay the pipes in. What would be the best option to fix 10 mm slate tiles to the floor. Options I am considering are,1, tile directly onto chipboard using granfix ultimate flex tile adhesive or similar.2, Overlay chipboard with 6mm tilebacker board and tile onto this or 3, overlay with exterior grade plywood and tile onto this. Quite a few companies actually supply 22mm chipboard systems to overlay an existing floor but usually recommend overlaying with plywood or backerboard before tiling. I want to avoid insulating the tiles from the pipes as much as I can.
Reply to Tiling over underfloor heating pipes in chipboard in the Australia Tiling Forum area at TilersForums.com
We had a water underfloor heating installed and tiled over. 3 months later we noticed many tiles...
Amethsyt
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
