Discuss Tiling patio area in the British & UK Tiling Forum area at TilersForums.com.
N
Nuddy
Hi all fellow fixers I'm a new member, hoping to share /learn about various tiling experiences/products .I'v just been to measure up for a quote to tile a patio area. The customer as just marked out the shape of the area to be tiled before his builder pours the concrete slab. The best way to describe the shape is like the 18yd box on a footy pitch (retangle with a D shape on top, area 35sqm). The tile is 1200 x 145mm wood effect porcelane from Porcelanosa has anyone laid these outside? I've told him the slab needs to be level with a fall away from the house, I know I will have to put some kind of expansion joint in as the with of this area is 8.5mtrs, but not sure if the concrete slabs expansion joint needs to be in the same place as the tiles exp/jt , can anyone shed any light on this please.
Also what adhesive/grout would you recomend? I mainly use Bal or weber floor adhesives and grouts, and I know most of them say they are suitable for exterior use, but I have only used these on small porches outside before,so not really exposed to the more extreme conditions you would get on a patio. want to be 100% sure I use the products that wont fail in 12mths time due weather etc..maybe someone as already tried and tested such aproduct.. All advise, tips, coments much appreciated.
Cheers!
John
davy_G
Fred, never dot and dab, madness!!
Nuddy, make sure the addy and grout are suitable for outside, ie frostproof, flexible, waterproof.
Whitebeam makes a good point about the expansion joint though. The slab will settle differently to the house as it is pre-existing so some sort of decoupling joint, even a bead of Silicon should be left along the join with the house.
Make sure the slab is properly cured before tiling, this will give a chance to see where the cracks are and how bad they are.
Water the slab as well after pouring, helps to stop surface cracks.
Reply to Tiling patio area in the British & UK Tiling Forum area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hi guys, had some great advice here before so thought I would ask here for advice again...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
Tiling patio area
    Votes: 9 5.8%
    Votes: 16 10.3%
    Votes: 10 6.4%
    Votes: 42 26.9%
    Votes: 21 13.5%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 3 1.9%
    Votes: 21 13.5%
    Votes: 19 12.2%
    Votes: 16 10.3%
    Votes: 8 5.1%
    Votes: 5 3.2%
