Discuss Tiling treated wall with zinsser 123 in the Canada Tile Advice area at TilersForums.com.
Hi really hope you can help, I have a small kitchen project and need to tile between worktop and kitchen cabinets, the old tiles have been removed and the tiled area has been patched as some plaster was displaced when the old tiles removed, all the walls have been treated with zinsser 123 acrylic primer is it ok to tile over the primer or should I remove the primer.
Regards mjv
Wesley
273
East Anglia
Hi, I’ve never tried tiling over zinsser primer, and probably wouldn’t try it. I did some painting in the summer for a customer (trying to stay afloat !!), and they bought zinsser 123 primer. When dry, after approx 24hrs, the adhesion wasn’t great and the dry film was soft and peeled off quite easily. I don’t believe it will take the weight of tile + adhesive.
I would suggest that u scrape off the zinsser in the area to be tiled, apply sbr, followed by adhesive and tile.
Who knows...it might work, but I wouldn’t trust it. Wesley
Thanks for your reply Wesley, I will take your advice sand/scrap off and prime, much appreciated :star:
Reply to Tiling treated wall with zinsser 123 in the Canada Tile Advice area at TilersForums.com
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
north east
What member type are you?
  1. Homeowner
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
