davemul
Hi guys, has anyone ever installed or tiled up to recessed wet room screens?
Ive ordered a 10mm thick screen and a pair of these recessed channels to go in the floor and wall
FD Wet Room Recessed Channel 10mm, save 61% off Rrp at fountaindirect.co.uk
From what I can see, there is a slight lip on the channel. So I guess I tile up to each side UNDER the lip of the channel fairly closely then silicon the gap between the two sides of tiles and lower the channel in to the lips rest on the tiles (flush). Then clear Silicon along the glass and upper lip of the channel and also possibly the lower lip and the tile surface
I'm using these as depth of channel is 10mm. The tiles are 9mm so including adhesive thickness, there should be no interruption to the tanking system. Unless I need to screw the channels down? in which case I guess ill Silicon the screw thread as I screw in
Just wondering if im accurate there and if anyone has installed similar systems before?
