Discuss Tiling up to kitchen worktop in the UK Tiling Forum area at TilersForums.com.
jgw1
You may see that I have posted around but they are different questions *honest*.
I am tiling a kitchen splash back this weekend. What is the recommended way to tile to the worktop.
I was going to:
1. Seal the worktop-wall join with silicone prior to tiling.
2. Tile the mosaics ontop of 2mm spacers to leave a gap between the tiles and worktop
3. Grout
4. Use BAL transparent silicone and corner tape (4mm) between worktop and grout/tile.
Any comments.
Wasn't sure if I tiled right up the worktop (which would be easier) whether it would look disproportionate with a 4mm bead of silicone at the bottom.
jgw1
OK,
Looks like I can do it either way - the important thing is to do it with silicone!
I am slightly worried about using a tile trim in the kitchen. Its U shaped and the two sides will be tiled up to the bottoms of the cabinets. The mosaics are coloured all the way through so won't look too bad if left unedged. The alternative is to add a trim - but a great big silver line on top the tiles will look unsightly in my head.
Do you always use a trim with mosaics that are coloured all the way through or can it look attractive without it?
Alberta Stone
Trim, both metal and plastic comes in a wide variety of designer colors these days so it is possible to get the right style to suit.
But glass and stone can look very good without any metals.
I never use metals on any stone product for edges unless they are specified by the owner.
But glazed tiles really need a metal trim to hide their biscuit look on the edge, although, some manufacturers make special edge tiles which eliminate the need for metals.
jgw1
Just to let you folks know I used silicone before tiling and after. This did the trick, one thing to watch is when smearing out the silicone first time round (sealing the gap between the worktop and the wall) that this will make the wall resistent to primers and the like. I found that in a few places I needed to rescore the surface. I could have taped up the wall as well as the worktop to avoid this.
Reply to Tiling up to kitchen worktop in the UK Tiling Forum area at TilersForums.com
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
We had our kitchen tiled last week and we're not at all happy with the work. The tiles aren't...
