Carl Morrison
Hi,
On with ensuite renovation and im going to tile up to a vaulted ceiling, probably about a 45degree angle. Is there a bead/trim you would advise? I can imagine it getting hard work getting it all perfect with a back cut on the porceleain tile and it will be hard to get a good edge without chipping.
Also on trims, im using a matt marble effect porcelain beige tile... what trims would you advise? chrome? / beige? square or round edge? Trims will mostly be used for external corners of partition wall between bath and shower, reveals of window and around a recess hole im planning in the shower cubicle for shampoos etc.
Any thoughts/advise welcomed!
