Discuss Tiling upper window recess in the British & UK Tiling Forum area at TilersForums.com.
Gazzer
Using a good non slip adhesive will sort it out. Spread the area to be tiled and spread a little on the back of the tile. Push the tile onto the area to be tiled and "twist" the tile in to get a good fix.
If in doubt you could always cut a length of wood the width of the window and prop the tiles up but i doubt you will need it if using a god adhesive.
grumpygrouter
Hi Mike, welcome to the forums. Any decent adhesive will hold up a tile in a window recess top. If you decide to use a support of some sort, be careful you don't knock your tile out of line by mistake. A slight sideways pressure can move it without you knowing and when you discover it late your addy has set and you then have to re-do the tile.:thumbsup:
Grumpy
White Room
I am tiling round the inside of a window recess including the top, ie the tiles will be facing the floor as if on a ceiling. Any tips please on keeping them in place while the adhesive sets!
If you need a prop try www.carobyn.com they do small one's called mini quick support I've used them for dry linning above windows to support plasterboard
Reply to Tiling upper window recess in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
