Discuss tiling walls in the UK Tiling Forum area at TilersForums.com.
poshman
hi all, ive got 33cmx 24cm tiles to tile my en suite and wall.
I am re tiling the cubicle shall i tank or seal the plasterboard wall when i take the tiles off ? i havent taken the tiles off yet but hopefully i can strip without damaging the plasterboard
the other walls have got bathroom emulsion on them, is it ok tile on top or can i buy some bonding to help the adhesive to stick the tiles to the walls
thank you P M
DHTiling
Hello P M..
IMO it is wise to tank shower walls if the option is there to do it..
You might find that taking the tiles off could destroy the walls, it just depends on how well secured they are to start with etc..
So if they do get damaged then it is usually quicker just to replace the boards in that area.
As for the other walls, it best practise to try and sand off any paint.. are the walls skimmed ..?
Trader Biggs
Hey poshman, yep replace plasterboards with a moisture board. Also for the other walls use your stanley knife and scrape a grid patteren on the walls so when the adhesive is troweld on it will grip to the plasterboard.Screw the exsisting plaster slabs with drywall screws to in sure they are strong enough to take the weight of the tile,also use bags of flexible white adhesive on the the walls (No buckets). Cheers
Reply to tiling walls in the UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
tiling walls
