Discuss Tiling window recess - advice needed please in the UK Tiling Forum area at TilersForums.com.
choran
Hi
I am new here
I have been re-doing my own bathroom for months. I have tiled the walls with large ceramic tiles and am now tiling around the window and into the recess but have hit a problem - HOW TO tile the top of the recess on the inside ie against gravity. The recess is 16cm deep and tiles are 25cm wide so am trying to get 4 tile pieces 16cmx25cm together with grout to stick without falling off. An added problem is that none of my walls are straight and the overhead part of the recess slopes upwards from window frame to wall so trying to fill the space with adhesive is making tiles to heavy and they just fall off again. Is there a special adhesive for this job? Do i need to get a board and prop it up against the tiles to keep them in place while the adhesive dries?
TIA
Caitriona
Reply to Tiling window recess - advice needed please in the UK Tiling Forum area at TilersForums.com
Hey everyone. Hope you are well. I want to learn how to tile and do a fairly basic bit of...
Tilers Forums on FB
