Discuss tiling window reveals. in the UK Tiling Forum area at TilersForums.com.
Good answer Daryl. Happy new year mate.My tip for tiling the window head....
1. Apply adhesive to the window head with your notched trowel
2. Skim the back of tile with the flat edge of your trowel
3. Firmly press the tile into place with a little twist / wiggle
The tile will stay exactly where you placed it with no need for battens / props / supports. I've stuck natural stones and some really heavy porcelain using this method. The only time I use a support is when I have had to apply extra adhesive to bed the tile out to "square" the window.
I hope this makes sense.
Good luck,
Daz
Do people push the trim into the reveals or into the wall sides? (if that makes sense)..... I normally tile the walls first and place beading into wall sides so my beading is done before the reveals are tiled. I can never judge how much of a over lap to bring out over the window reveal. I often overlap too much and end up packing out the reveals too much.
Reply to tiling window reveals. in the UK Tiling Forum area at TilersForums.com
