Discuss Tiling window reveals in the Australia Tiling Forum area at TilersForums.com.
SB4U
Hi Fellas. I've (nearly) finished tiling my en-suite walls now and want to start on the window reveals soon. Do you have any hints or tips for a nice looking finish?
As recommended in a previous post of mine, I pulled the bottom tiles up above the window sill (by up to 10mm at its worst), and I also pulled the top tile down a bit on one side to level the head up. I didn't pull the sides in though so they're level with the reveal. Should I try to use tile adhesive to pack the head and sill level with the edge of the tile in advance, let it go off then tile on it as normal? Or just try to pack it out as I go?
I was planning on using some trim too if that's relevant. Either a curved trim or a flat straight-edge stainless steel effect.
I've added some pics in case that helps you visualise.
Steve
p4ulo
Go for flat-edged stainless trim, the curved stuff looks a bit 90's nowadays. (and I find it harder to get it to all line up).
Get yourself a decent mitre box / or mitre saw, and measure twice and cut once!
Measure the cut the bottom trim first, deciding whether you want a gap between it and tile, or you want it to butt-up.
Butt up looks better IMHO, but its hard to get it spot on.
Work from the bottom up. It's trickey, and depending on how quick your adhesive goes off, you might want to cut and fit the bottom tiles and trim before doing the rest of it.....Good luck, keep the pictures coming!
SB4U
Reasonably pleased with how it turned out. Just got to grout it of course. Couldn't pack the tiles up enough to hide the ridge unfortunately Dan.
Luckily this photo is sufficiently blurred so that you can't see the lippage between the trim and some of the tiles so I've totally got away with that.
SB4U
Many thanks for the kind replies guys. I don't think it would stand close strutiny to be honest but I'm pretty happy with it.
Actually I've realised why the pic looks so blurred. My phone takes massive pics that are non standard ratios so when I reduced the the size to 800x600 it squeezed it in at the sides. I'm not sure how to edit the post to swap it for a better one.
Have u tried uploaping full size?
Reply to Tiling window reveals in the Australia Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
