Discuss Tiling window sill in the Canada Tile Advice area at TilersForums.com.
Hello all,
I’m tiling the bathroom and it currently has a typical new-build MDF window sill. I want to tile the sill and my question is:
Do I tile on the MDF or replace it with something. If I replace it, what would I use?
It’s a timber frame house so I’m assuming there will be a bit of wood and insulation beneath the MDF so what’s the best way to make good?
Secondly: should I move the toilet out to tile behind it or would you tile around it? See pic.
Thank you!
Dan
Admin
Staff member
5,092
1,323
Staffordshire, UK
I'd move the loo forward and tile behind it. It always looks better. And you can still lift the lid off the cistern then.
The sill I'd perhaps cut the lip off so it's flush with the wall and then overboard it with a cement board and tank it? (Wait for the tilers to reply im not ofay with the new gear).
Having said that. It's not going to get water on it there. That's the basin isn't it not part of a shower (bottom left of pic). So perhaps just cut the sill flush and then sand the paint off, prime and tile it?
Again wait for the lads to reply.
Reply to Tiling window sill in the Canada Tile Advice area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
K
I'm looking for a supplier of 8" bullnose red/brown quarry tiles that I can use as a window...
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
wiltshire
What member type are you?
  1. DIY Wall and Floor Tiler
Tiling window sill
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
