Discuss tips for laying slate in the British & UK Tiling Forum area at TilersForums.com.
N
new tiler
Hi everyone.
hi i wondered if anyone can give me any tips on laying a slate floor i have done ceramic floors but no slate yet, and am quite worried due to lack of confidence, i do have some questions if anyone would be kind enough to answer, ok i think i wont be able to use my rubi as i think slate splinters so ill use my wet cutter also after laying floor how long do i have to leave it untill sealing and do i lay, seal, grout, or lay, grout, seal, also after sealing can i grout straight after have read a few conflicting posts but i guess people do things a bit different so thanks guys :thumbsup:
N
new tiler
Re: any tips for laying slate floor
Thanks tj im laying it in a kitchen and small hallway on concrete floor not really sure what the slate is as my client has just told me the price is was when she went down so got to cheak out what she really wants before i buy it, i was also wondering if i should hose the tiles down to clean any dust off prior to laying, how long would you leave it before sealing as the slate would be wet from cleaning..
Time's Ran Out
When you collate the tiles into good/indifferent/bad and based on thickness/colour/quality thats when I normally take a sponge just to wipe any muck off the 2 sides. I wouldn't go overboard with the water as it could be retained in the slate and affect the adhesive.
When you've finished all the tiling or part depending on area and your speed, clean down that day and it will be ready to seal the next day but try and tile as dry and clean as possible or you will not be able to seal the tiles till they are dry.
Based on her price for the slate and where she bought it from, you should be able to tell its quality. Calibrated is best for fixing but it sometimes can lack a bit of colour.:thumbsup:
N
new tiler
Thanks i was thinking about cleaning then sealing before i lay them as i could grout them straight after then seal again after cleaning does anyone do it this way, also because of the difference in size i was thinking of starting with starting with the thickest at one end and grading down to the thinist as its going through a door to a small entrance way and not a very large kitchen, i have found out my client wants shera multicolour slate.
Time's Ran Out
If you clean them first that fine but you will not be able to seal them till they are dry! Catch 22.
Collate the tiles - Quality/thickness/colour.
If you can use all the thick pieces in one area without it affecting your overall blend of colours thats fine .
Don't forget you'll need plenty of adhesive for uncalibrated slate and I tend to use a fast set so it doesn't slump/draw the tile down as it sets.
Nice wide joint and IMO sandstone or sand & cement grout.
Reply to tips for laying slate in the British & UK Tiling Forum area at TilersForums.com
Hi all, We had an outdoor limestone patio laid at the start of June (finished circa 07/06/24)...
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
