Discuss To be reactivated or not to be reactivated? Electrical Advice in the Electrical Advice area at TilersForums.com.
To be reactivated or not to be reactivated? Discussion ThreadTo be reactivated or not to be reactivated? Electrical Advice
I ripped off the old cracked coverings on a wall to install new gyproc. I found in the wall an electrical single gang box (without the receptacle). The white and black wires were black-taped over.
I removed the tape and connected both wires to this device. I did this process twice. First by putting the black wire to the right side of device/white wire to left side of device. Then I switched wires around. In both instances the bottom center orange light of the device illuminated [open ground]
Then I pushed in the round black button that says: "Push to check GFCI", and in both repeated instances the bottom left light, and the bottom center light both illuminated [hot/neutral rev]
I want to put a receptacle in this single gang box so that the room will have an additional plug-in.
Can an electrician please tell me if those READINGS suggest I should not reactivate that buried box...or is it perfectly okay to make this an operating receptacle again?
PS: I discovered that although buried behind the wall, it is still connected to other active receptacles/lights in the house.
Thank you
To be reactivated or not to be reactivated? for the original thread on Electricians Forums
Reply to To be reactivated or not to be reactivated? Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
