mmmadman
Hi All
I have a question about priming, I have bought the Ardex Waterproof Protection System to tank around where my shower is going and the other walls if there is any left.
The shop said to prime the wall first with an SBR primer before using the Ardex kit.
On the Ardex box it says no primer required.
My substrate is, plasterboard that was tiled, I removed the tiles and old addy and the old plaster skim, off with this came a layer of the plasterboard cardboard.
I then coated the walls with the Granfix wetroom system and tiled using Granfix tubbed addy.
This is where it all went down hill, pear shaped and T*ts up, see my thread titled, "How to tackle shop miss sold adhesive"
Here:
http://www.tilersforums.com/43-tiling-forum/73425-advice-how-tackle-shop-miss-sold.html
I had to remove all the tiles and most of the addy just scraped off as it was still soft, even after a week. To remove the remaining addy I used a wallpaper stripper but this took the Granfix latex type membrane with it. I am now back down to a layer of cardboard on the face of the plasterboard with the odd nick in it which has revealed the plaster in the board.
Back to my question, do I prime this surface with SBR first?
Do I tank the whole room if I have any of the Ardex left over from the bath/shower area?
My tiles are 200mm x 500mm ceramic and I am now going to use Weber flexible powdered adhesive, as I should of done in the first place, :mad2::mad2::mad2: lol...!!!
Many thanks all, cheers...
Here:
