Discuss Toilet / Semi Ped Sink / Porcelain Tiles in the British & UK Tiling Forum area at TilersForums.com.
L
Lupen
Chaps,
Wonder if you could help clarify a couple of questions :
- Do I need to, or is it advisable, to seal porcelain tiles (Not polished) ?
- About to mount a semi ped sink onto the tiles, and seen the tip to use silicon sealant between the tiles and sink. Should I put on a bead and let it go off, or just fit the sink with the silicon wet ?? (Just conscious as I tighten it may compress down to nothing)
- Similarly, I am about to mount the toilet, and was going to silicon the base... should I pre-bead, fit wet, or just go around the base after it's in place. (Its a back to the wall, no access type toilet) ?
All on porc tiles BTW.... Wow, this has been a steep learning curve :smilewinkgrin:
Cheers,
Paul.
Deleted member 1779
Oh and if you havent sorted your drilling solution for the basin then we do the drills !
You'll need to cut holes in the tiles for the fisher fixing kits etc
Reply to Toilet / Semi Ped Sink / Porcelain Tiles in the British & UK Tiling Forum area at TilersForums.com
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
