K
kkelly77
Hi all,
I started putting up my wall tiles today. All was going fine however, it appears the gap between tiles at the internal corner is way too big(see photo). All tiles are level horizontally and vertically so I assume the walls are off. I couldn't add extra tile as I would be cutting strips a few mm's wide to compensate. Can anyone advise what should I do in this situation?
Also, do you need to let the adhesive set for 24hrs before you can grout or can you grout sooner?
K
K
