Found a 1200mm tile cutter for around £100 on amazon.
Click here to check it out on Amazon with more pictures.
Heavy Duty Manual Tile Cutter 1200mm
Cutting range 35 to 1200MM with up to 15mm Thickness
Product features:
There's a 1000mm one here too. https://amzn.to/4f29nsm
Part Number | 347704 |
Package Dimensions | 148 x 27 x 19 cm; 21.14 kg |
Item model number | 347704 |
Size | 1200mm |
Item Package Quantity | 1 |
Batteries included? | No |
Batteries Required? | No |
Item Weight | 21.1 kg |
Additional Information
ASIN | B07JKXLHBM |
Customer Reviews | 4.1 4.1 out of 5 stars 105 ratings 4.1 out of 5 stars |
Best Sellers Rank | 89,152 in DIY & Tools (See Top 100 in DIY & Tools) 49 in Hand Tile Cutters |
Date First Available | 19 Oct. 2018 |
Warranty & Support
Amazon.com Return Policy:Regardless of your statutory right of withdrawal, you enjoy a 30-day right of return for many products. For exceptions and conditions, see Return details.Product description
Product features:
- Solid rail with 28 ball bearings for extra precise stable cuts
- Eight adjustable bolts for calibrating the cutting wheel and stablize sliding part
- Laser light cutting guide for accurate positioning
- Self oil feeding system
- Quick press-release screws makes the adjustment distance easier.
- Foldable side supports for large size tiles
- Straight and diagonal the cutting possible in every point
- Cuts as narrow as 1cm of tile side
As an Amazon Associate we earn from qualifying purchases.
