Trailing Edge Pull Cord Dimmer Switch. Discussion ThreadTrailing Edge Pull Cord Dimmer Switch. Electrical Advice
I want to fit a Trailing Edge Pull Cord Dimmer Switch in the bathroom with 2 dimmable LED bulbs.
LED dimming range is 5-100w for the switch.
Light fitting takes two bulbs.
What is the Max Wattage of each dimmable LED bulb that I can safely use?
Thanks, John.
Trailing Edge Pull Cord Dimmer Switch. for the original thread on Electricians Forums
Thanks, John.
