Discuss Trav on plaster board walls in Bathroom? in the Bathroom Tiling Advice area at TilersForums.com.
2020Tiling
Hi, I've got a trav job too price up wall and floors in a bathroom and the customer has got large format trav for his bathroom but most of the walls are plaster boarded and his floor is floor boards that will need over boarding. would 18mm ply be ok for the floor? and would I have to over board walls? Cheers! :smilewinkgrin:
m3fitter
skimmed p/board is only 20kg per sq.metre, unskimmed 32kg, if large format could be 18-20mm trav ! then reboard with aquapanel cement board to take the weight, the floor can be ditra'd if boards are solid and true, or if floorboards are unsound and loose, either screw them securely and glue & screw aquapanel to create a better tiling substrate and create rigidity, or the full monty, remove floorboards and put down 25mm wbp ply, remember to always prime wood with acrylic primer.. ;-) hope it helped !
2020Tiling
Thank's for your input :) The plaster board walls are un skimmed but have what looks like gloss paint on under the wall paper that is currently on. Is it a must too fit an uncouple membrane on the floor with this job? as I thought the un couple membrane only works with separate substrates and not deflection?
m3fitter
i've used ditra for 8 years now, switching from aquapanel, never had a call back, a failure, no grout ever has cracked on a wooden floor, tiled with thin limestone, travertine, marble... just make sure the existing substrate is secure....and use your judgement... i offer a 5 year guarantee on all my work, and am happy to use uncoupling on wooden substrates, and now on all UFH substrates as per BS !!
Reply to Trav on plaster board walls in Bathroom? in the Bathroom Tiling Advice area at TilersForums.com
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Unsolved
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
