Discuss Travatine tiles cracking on underfloor heating system - HELP! in the British & UK Tiling Forum area at TilersForums.com.
Rex
Help!
Can anyone please advice me on how to solve the following problem...
Have travatine marble tiles laid on top of an underfloor heating system, and they have started to crack in a row along the door threshold.
Laid ontop of screed floor, and I think without any membrane.
If anyone can offer a simple solution for this, I'll be very grateful.
Will patching in with Ditra at the problem area solve it?
DHTiling
Ahh i see......you need to put an expansion joint at this point....leave about a 5mm joint over that point and fill with a matching Silicon...
You have 2 individual substrates that are expanding against each other and to use an isolation membrane would only work if across the whole floor area but if you put in a cold expansion joint ( Silicon ) then that will relieve some of the stress causing the tiles to crack..
Rex
Apologies for my further questions but I'm not a tiler.
How do you put in an expansion joint?
Take up tiles, excavate in the wall foundation an expansion joint?
Or replace new tiles to a lesser width allowing an expansion joint filled with Silicon?
Thank you for your speedy response.
Also, as no ditra membrane was laid under the entire floor is it likely to crack elsewhere?
Reply to Travatine tiles cracking on underfloor heating system - HELP! in the British & UK Tiling Forum area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
We had a water underfloor heating installed and tiled over. 3 months later we noticed many tiles...
Amethsyt
Hi guys, Hope you are all having a fantastic Xmas. To cut a long story short I have installed...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
