U
Unregistered
Hi I've forgotton my password sorry!
Just about to organise 145m2 of an old farmhouse in France to be ideally covered
in what they call a 'Classic medium Travertine' 12mm from Turkey.
The make of sub floor is 100mm concrete slab, 53mm insulation electric mats
covered with a 35 -40mm top screed French method. So although taking longer
to heat up the screed stays hotter for longer when switched off or turned down.
If putting Travertine on top will there a problem unless a deflecting membrane is
used or if matts set in 35mm screed the heat will be more even.
Appreciate any advise
Regards
Martin
Cambridge
Regards
Martin
Cambridge
