Discuss Travertine external corners and window recess. in the British & UK Tiling Forum area at TilersForums.com.
bendy
Good morning all,
I'm about to start fitting 600 x 400 travertine wall tiles next week in my bathroom and am a little unsure as to the best way to go round external corner and also install the edging for the window recess.
The common ways seem to be either Mitre or Butt join the tiles or to bullnose a radius onto them.
I just wanted to know what you think is best and if you could post any pictures of examples. The picture i've looked at on the forum tend to show the whole room, so i can't see the detail for corners or recesses.
I was looking at geting a 3/16" profiling tool and bull nosing but the delivery time can be upto two weeks and i can't hold off that long. Another option would be to machine radius them by hand with diamond grit disks but i can't seem to find anywhere that does the disks.
Many thanks
Ben.
I
Ian
Bullnosing is the best finish IMO, here's a close up pic of a window reveal.
10mm profile with mitred internal corners.
Sent via Tapatalk for iPhone
Topshop
If the travertine is honed and not polished you can put the bullnose or bevel the edge by hand with some sand paper. Travertine is a soft stone. Affix the sand paper to a board or sanding block to keep the line straight. If the travertine is polished you can do the same method but finish it off at a higher grit them some marble polishing paste or 5x powder.
bendy
The tiles are Honed, not polished. I imagine grit size would be 60-80 but would you use just normal sandpaper or a diamond type?
I have a variable speed polishing tool with velcro backer disc so are there discs available for this?
I
Ian
Thanks for the prompt reply Bri.
That looks stunning. Do you set the wall tile first or the recess tile or do you line then up at the same time?
Wall first, then profile the tiles for the reveal, then cut them to size, then fit.
Pads are available, you will need a router bit to get the profile that I pictured, the pads are then used to smooth the tile back to the honed finish of the face of the tile. All my equipment came from Stonetools
Reply to Travertine external corners and window recess. in the British & UK Tiling Forum area at TilersForums.com
    • Winner
Looking to do a few mitred external corners this week (600x300x9 porcelain). Practiced the cuts...
8K
hmtiling
H
H
I'm tiling an ensuite this week, half way up the wall that finishes with a bull nose border...
KateJ
K
Just revisited a lady I originally quoted to tile a bathroom for about 6 weeks ago. She decided...
5K
Tilled an en-suite shower room about 7yrs ago, there is no window only an extractor fan. The...
9K
Hi everyone I have two external balconys that need refurbishment as leaking, The maintenance...
7K
mike111
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
